Explorer
May 10, 2024
How to: STM32F103C8T6 in a PCB design?
I'm a beginner so bear with me:
I am making a calculator with a STM32 Blue Pill and would like to create a PCB so that the calculator can be decently compact. I am unclear on some things though. Is it normal to place the entire Blue Pill in a PCB design? I couldn't find a footprint for it in KiCAD, however I did find the footprint for just the chip itself (the STM32F103C8T6). This leads me to believe it would be unusual to use the Blue Pill in this way... however if I use just the chip, how would I upload my code to it? And, given how small it is, how would I ever be able to solder it properly to the PCB? I'm just a little unclear on what the normal thing to do is, and also how to do it. Any guidance is much appreciated!
May 10, 2024
I've put RPi Pico boards as the MCU / USB-VCP on test boards I've built in recent quarters. Cost less than FTDI adapters
Isn't the Blue Pill just dual-in-line headers? Do you need a symbol? Can't KiCad let you create one?
Perhaps you can find a symbol via Google or GitHub.
Not everything is going to be prebuilt in a form you can cut-n-paste
