liaifat85Best answer
November 28, 2023
This error message means that the debugger is trying to access the source code for the memset()  function but cannot find it. Please follow the instructions given by STTwo-32. Recheck your optimization level and memory allocation. If you ever consider making a customized board with STM32, you can try this.
STTwo-32
Hello @Girish1
I think you should check your debug configuration settings (Optimization Level, and Debug Level). For that, I advise you to check this post (not updated but it Can help) and this video. it may help you. Also, have a look at this article in the debug section: How to make sure the STM32 starts properly in our design?
Best Regards.
STTwo-32
November 28, 2023
Girish1Author
make all src/main.d:1: *** multiple target patterns. Stop. how to solve this error
David Littell
Senior II
December 15, 2023
Don't hijack threads, even ones that you started.
