acapola
How to set RDP level2 without a password with STM32_Programmer_CLI
  • July 16, 2024
  • 1791 views
I am using NUCLEO-u5a5zj-q, I tried this:
sru@sru-pqs-dell:~/repos/pqkey$ STM32_Programmer_CLI --connect port=swd index=2 -halt --optionbytes displ -ob nSWBOOT0=0 nBOOT0=1 -lockRDP2 0xFFFFFFFF 0xFFFFFFFF
 STM32CubeProgrammer v2.16.0
ST-LINK SN : 004900253532510831333430
ST-LINK FW : V3J15M6
Board : NUCLEO-U5A5ZJ-Q
Voltage : 3,28V
SWD freq : 8000 KHz
Connect mode: Normal
Reset mode : Software reset
Device ID : 0x481
Revision ID : Rev X
Device name : STM32U5xx
Flash size : 4 MBytes (default)
Start Address : 8000000
Device type : MCU
Device CPU : Cortex-M33
BL Version : 0x92
Debug in Low Power mode enabled
Core halted
UPLOADING OPTION BYTES DATA ...
 Bank : 0x00
 Address : 0x40022040
[==================================================] 100%
 Bank : 0x01
 Address : 0x40022068
OPTION BYTES BANK: 0
 Read Out Protection:
 RDP : 0xAA (Level 0, no protection)
 BOR Level:
 BOR_LEV : 0x0 (BOR Level 0, reset level threshold is around 1.7 V)
 User Configuration:
 TZEN : 0x0 (Global TrustZone security disabled)
 nRST_STOP : 0x1 (No reset generated when entering Stop mode)
 nRST_STDBY : 0x1 (No reset generated when entering Standby mode)
 nRST_SHDW : 0x1 (No reset generated when entering the Shutdown mode)
 SRAM1345_RST : 0x1 (SRAM1, SRAM3,SRAM4 and SRAM5 not erased when a system reset occurs)
 IWDG_SW : 0x1 (Software independent watchdog)
 IWDG_STOP : 0x1 (IWDG counter active in stop mode)
 IWDG_STDBY : 0x1 (IWDG counter active in standby mode)
 WWDG_SW : 0x1 (Software window watchdog)
 SWAP_BANK : 0x0 (Bank 1 and bank 2 address are not swapped)
 DBANK : 0x1 (Dual-bank Flash with contiguous addresses)
 BKPRAM_ECC : 0x1 (Backup RAM ECC check disabled)
 SRAM3_ECC : 0x1 (SRAM3 ECC check disabled)
 SRAM2_ECC : 0x1 (SRAM2 ECC check disabled)
 SRAM2_RST : 0x1 (SRAM2 is not erased when a system reset occurs)
 nSWBOOT0 : 0x1 (BOOT0 taken from PH3/BOOT0 pin)
 nBOOT0 : 0x1 (nBOOT0 = 1)
 PA15_PUPEN : 0x1 (USB power delivery dead-battery disabled/ TDI pull-up activated)
 IO_VDD_HSLV : 0x0 (High-speed IO at low VDD voltage feature disabled (VDD can exceed 2.5 V))
 IO_VDDIO2_HSLV: 0x0 (High-speed IO at low VDDIO2 voltage feature disabled (VDDIO2 can exceed 2.5 V))
 Boot Configuration:
 NSBOOTADD0 : 0x100000 (0x8000000)
 NSBOOTADD1 : 0x17F200 (0xBF90000)
 Write Protection 1:
 WRP1A_PSTRT : 0xFF (0x81FE000)
 WRP1A_PEND : 0x0 (0x8000000)
 UNLOCK_1A : 0x1 (WRP1A start and end pages unlocked)
 WRP1B_PSTRT : 0xFF (0x81FE000)
 WRP1B_PEND : 0x0 (0x8000000)
 UNLOCK_1B : 0x1 (WRP1B start and end pages unlocked)
OPTION BYTES BANK: 1
 Write Protection 2:
 WRP2A_PSTRT : 0xFF (0x83FE000)
 WRP2A_PEND : 0x0 (0x8200000)
 UNLOCK_2A : 0x1 (WRP2A start and end pages unlocked)
 WRP2B_PSTRT : 0xFF (0x83FE000)
 WRP2B_PEND : 0x0 (0x8200000)
 UNLOCK_2B : 0x1 (WRP2B start and end pages unlocked)
PROGRAMMING OPTION BYTES AREA ...
Warning: Option Byte: nboot0, value: 0x1, was not modified.
 Bank : 0x00
Reconnecting...
Reconnected !
 Bank : 0x00
 Bank : 0x01
OPTION BYTE PROGRAMMING VERIFICATION:
Option Bytes successfully programmed
Time elapsed during option Bytes configuration: 00:00:02.127
Lock RDP2 password successfully done
sru@sru-pqs-dell:~/repos/pqkey$ ./status-stm32u5a5 2
+ index=2
+ name=2
+ addr=0x08000000
+ STM32_Programmer_CLI --connect port=swd index=2 -halt --power off index=2 --power on index=2
Voltage : 3,28V
SWD freq : 8000 KHz
Device ID : 0x481
Revision ID : Rev X
Device type : MCU
BL Version : 0x92
Core halted
Power OFF...
Drives the target power pin out of the (onboard) ST-Link.
Info: Power ON/OFF maybe not available on your Board [also not available on standalone probes]
Power OFF the board finished with success !
Power ON...
Power ON the board finished with success !
+ STM32_Programmer_CLI --connect port=swd index=2 -halt --optionbytes displ --blankcheck
Voltage : 3,28V
SWD freq : 8000 KHz
Device ID : 0x481
Revision ID : Rev X
Device type : MCU
BL Version : 0x92
Core halted
 Bank : 0x00
 Bank : 0x01
 BOR Level:
 User Configuration:
 nSWBOOT0 : 0x0 (BOOT0 taken from the option bit nBOOT0)
 Boot Configuration:
 Write Protection 1:
 Write Protection 2:
Flash memory blank checking...
Time elapsed during the blank check operation is: 00:00:00.015
Warning: Flash memory is not empty at 0x08000000.
As you can see, the RDP level is still 0 (and later on I could still dump all memories).
On the same board I have been able to set RDP level 2 without password using the GUI version (STM32CubeProgrammer), so the setup was right.
Best answer by Diane POMABIA
Hello @acapola
To be clear, if you go to RDP level 2 without setting a password beforehand, you won't be able to go back.
Here is  examples of a command, you can configure the right path for your PC.
Without Password
@ECHO OFF
SETLOCAL
SET TOOLDIR=c:\Program Files\STMicroelectronics\STM32Cube\CubeProgrammer1.14\bin
SET TOOL=%TOOLDIR%\STM32_Programmer_CLI.exe
SET MY_CURR_DIR=%cd%
@ECHO ON
cd %TOOLDIR%
"%TOOL%" -c port=SWD mode=HOTPLUG -ob displ
"%TOOL%" -c port=SWD mode=HOTPLUG -ob RDP=0xCC
cd %MY_CURR_DIR%
@ENDLOCAL
@PAUSE
With password:
@ECHO OFF
SETLOCAL
@ECHO ON
cd %TOOLDIR%
"%TOOL%" -c port=SWD mode=HOTPLUG -lockRDP2 0x12345678 0xABCDEFAB
"%TOOL%" -c port=SWD mode=HOTPLUG -unlockRDP2 0x12345678 0xABCDEFAB
"%TOOL%" -c port=SWD mode=HOTPLUG -ob RDP=0xAA
cd %MY_CURR_DIR%
@ENDLOCAL
@PAUSE
DianeP
Diane POMABIABest answer
Hello @acapola
Without Password
@ECHO OFF
SETLOCAL
@ECHO ON
cd %TOOLDIR%
cd %MY_CURR_DIR%
@ENDLOCAL
@PAUSE
With password:
@ECHO OFF
SETLOCAL
@ECHO ON
cd %TOOLDIR%
cd %MY_CURR_DIR%
@ENDLOCAL
@PAUSE
DianeP
acapola
acapolaAuthor
Note that without password, the second attempt to display option bytes is failing and it is expected since we have locked the JTAG.
