kchak
How to run application from different internal flash location in STM32H743
i have two projects, one (application A) build to execute from 0x08000000 and another one (application B) from 0x08040000.
Can you guide me about, how can i switch from Application A to Application B?
Thank you.
    The methods would be the same as other STM32 parts, and Cortex-Mx processors.
    Review IAP and loader examples.
    I'm sure you could find a couple of examples and app notes if you looked at little
    https://www.st.com/content/ccc/resource/technical/document/application_note/27/38/37/58/c2/8c/40/07/DM00161366.pdf/files/DM00161366.pdf/jcr:content/translations/en.DM00161366.pdf
    STM32Cube_FW_H7_V1.3.0\Projects\STM32H743I_EVAL\Applications\IAP\IAP_Main\readme.txt
    kchak
    kchakAuthor
    Thank you Clive, for the direction. it helps.:smiling_face_with_smiling_eyes:
