Abdelhak GOUDJIL
Mar 18, 2018 5:06 PM UTC
How to retrieve the data converted by ADC using DMA on simulink ?
Posted on March 18, 2018 at 18:06
I want to use the ADC and the DMA on Simulink
as follows
The ADC is triggered by
the rising edge
of Timer 2 which generates a PWM signal with a frequency of 100
kHz
So, I want to retrieve the 132 first data converted by ADC at every 1 second.
Any idea how to use DMA (or buffer) on
Simulink
and how to retrieve the 132 first data converted by ADC at every 1 second.
Thank you
very much.
Note: this post was migrated and contained many threaded conversations, some content may be missing.
    Andrew Neil
    Mar 18, 2018 7:06 PM UTC
    Posted on March 18, 2018 at 20:06
    Simulink
    Is that not covered in the Simulink Documentation?
    https://uk.mathworks.com/help/simulink/index.html
    Abdelhak GOUDJIL
    Mar 19, 2018 4:33 PM UTC
    Posted on March 19, 2018 at 16:33
    Thank you Andrew for your response,
    But I want to
    know
    how to
    configure ADC and DMA on CubeMX and how to read DMA data under Simulink?
    Thanks in advance
    Andrew Neil
    Mar 19, 2018 6:34 PM UTC
    Posted on March 19, 2018 at 18:34
    So that's two separate questions - isn't it:
    1. how to
    2. how to read DMA data under Simulink?
    Is the fact that it came via DMA even relevant to Simulink?
