TKopp.67
May 4, 2022 8:51 AM UTC
How to retain some data in flash memory during appplication running on STM32F405 ?
Hi everyone,
For some reasons, i need to store 3 uint16 in flash (once) when my application is running. Of course the goal is that those values will remain after a power down / reset. Does someone knows how to do this properly ?
Do i need to define a new area in the linker (located in flash area) ?
Thanks for your answer,
Best Regards,
Thomas
TKopp.67
TKopp.67Author
May 4, 2022 9:04 AM UTC
Or better a zone in the memory area that would be retain after a reflash of the MCU ?
Andrew Neil
May 4, 2022 1:38 PM UTC
May 4, 2022 1:39 PM UTC
You can store memory to flash, which is retained through power resets. There is an EEPROM emulation library you can search for. People often use the last (or last two) pages in flash to do this.
TKopp.67
TKopp.67Author
May 4, 2022 2:50 PM UTC
Oh thanks guys,
Will check about that feature right now.
Best Regards,
Thomas
