Olivier FAURAX
Jan 2, 2017 11:42 AM UTC
How to properly setup printf with Keil µVision and STM32L151C8T6A ?
Posted on January 02, 2017 at 12:42
I'm unable to get the printf output in the keil µVision IDE, so I need a
https://community.st.com/tags♯/?tags=checklist
to know if my setup is correct.
In the Keil project, I configured ST-Link Trace with Core Clock 32Mhz and all ITM port ticked (only number 0 needed, perhaps ?).
I run the debugger with the 'printf window' open.
I tried:
  • printf
  • ITM_SendChar
And nothing shows in the printf window. Is there something I missed to check?
#checklist
    Tesla DeLoreanBest answer
    Jan 2, 2017 2:57 PM UTC
    Posted on January 02, 2017 at 14:57
    It is where the trace data comes out, so yes.
    For printf() to work in Keil you must supply supporting routines to use ITM_SendChar()
    // Rough SWV support in Keil, requires PB3/SWO to be connected to debugger
    #include <rt_misc.h>
    #pragma import(__use_no_semihosting_swi)
    struct __FILE { int handle; /* Add whatever you need here */ };
    FILE __stdout;
    FILE __stdin;
    int fputc(int ch, FILE *f)
     ITM_SendChar(ch);
     return(ch);
    int fgetc(FILE *f)
     char ch;
    ch = 1;
     return((int)ch);
    int ferror(FILE *f)
     /* Your implementation of ferror */
     return EOF;
    void _ttywrch(int ch)
     ITM_SendChar(ch);
    void _sys_exit(int return_code)
    label: goto label; /* endless loop */
    Jan 2, 2017 11:50 AM UTC
    Posted on January 02, 2017 at 12:50
    Is PB3 SWO connected to the ST-LINK?
    Olivier FAURAX
    Jan 2, 2017 2:35 PM UTC
    Posted on January 02, 2017 at 14:35
    Thanks for the reply and happy new year.
    No, PB3 is not connected.
    According to my doc, only PB4 (TRST), PA14 (SWCLK) and PA13 (SWIO) are connected.
    I try to use Serial Wire, am I required to connect PB3?
    FILE __stdout;
    FILE __stdin;
     ITM_SendChar(ch);
     return(ch);
    int fgetc(FILE *f)
     char ch;
    ch = 1;
     return((int)ch);
    int ferror(FILE *f)
     return EOF;
     ITM_SendChar(ch);
