mehmet.karakaya
how to interface 3V3 pins with 5 V logic ?
  • September 7, 2010
  • 4 replies
  • 810 views
Posted on September 07, 2010 at 09:44
    May 17, 2011
    Posted on May 17, 2011 at 14:05
    It's a universal topic, try Googling.
    Depends on the type of logic you are interfacing to (VOL/VOH/VIL/VIH), you can add buffering logic, or resistor networks, or use open-collector outputs and pull ups. Some of the STM32 pins are 5V tolerant, check the TRM.
    Andrew Neil
    As clive1 says, a direct connection may be acceptable - see the datasheets of all devices concerned.
    In extremis, specific logic-level translator chips are available.
    Here's a couple of App Notes from NXP which might be helpful:
    http://ics.nxp.com/support/documents/interface/pdf/an10441.pdf
    http://ics.nxp.com/support/documents/interface/pdf/an97055.pdf
    Andrew Neil
    Andrew Neil
    Posted on May 17, 2011 at 14:06
    ... as Texas Instruments calls them:
    http://focus.ti.com/lit/ml/scyb018d/scyb018d.pdf
