PESHWA
how to get usb status
HELLO
I am working with Xmodem  file transferring vai usb  I want to know how i get know about USB status like  Ready or not how we get in UART
while (!(HAL_UART_GetState(&huart4) == HAL_UART_STATE_READY) && wTimeout) {
wTimeout--;
if (HAL_UART_GetState(&huart4) == HAL_UART_STATE_READY)
break;
like this we have any things in USB i may not aware let me know
TDKBest answer
December 15, 2023
There isn't a built-in function to do this, but you can make your own.
It depends on the USB class you're using. Here is the check for CDC:
uint8_t CDC_Transmit_HS(uint8_t* Buf, uint16_t Len)
 uint8_t result = USBD_OK;
 /* USER CODE BEGIN 12 */
 USBD_CDC_HandleTypeDef *hcdc = (USBD_CDC_HandleTypeDef*)hUsbDeviceHS.pClassData;
 if (hcdc->TxState != 0) {
 return USBD_BUSY;
 USBD_CDC_SetTxBuffer(&hUsbDeviceHS, Buf, Len);
 result = USBD_CDC_TransmitPacket(&hUsbDeviceHS);
 /* USER CODE END 12 */
 return result;
Be careful not to dereference null pointers.
TDKBest answer
December 15, 2023
 return USBD_BUSY;
 return result;
Roger SHIVELY
Hello @PESHWA ,
There has been a case created to resolve this question and we will be reaching out to you directly.
Regards,
Roger
