Rakshith ks
How to enable GPIO 5V tolerance
Posted on April 12, 2018 at 14:37
Hai,
we are using a STM32F070RBT6 controller for development  i need a clarification regarding I/O's
if we want use FT 5 V tolerant I/O we need add any external component or just enable has high.
Rakshith
    Andrew Neil
    Posted on April 12, 2018 at 15:26
    Whether a pin is 5V tolerant or not is due to the physical hardware of that pin - it is not configurable.
    Rakshith ks
    Posted on April 12, 2018 at 15:47
    It's a 5V I/o pin .we configured has high but we getting 1.6V..
    Rakshith
    �Sent from TypeApp ​
    Andrew Neil
    Posted on April 12, 2018 at 15:56
    Your question, 'How to enable GPIO 5V tolerance' has been answered.
    If your output is not driving to the expected level, that's a different question.
    Suggest you mark this thread as answered, and start a new thread about your output drive problem.
    But you will need to give a lot more detail for anyone to be able to help in that new thread:
    • A schematic
    • Details of how you are observing the output
    • A minimal but complete code example which illustrates the problem.
    Khouloud GARSI
    Posted on April 12, 2018 at 15:39
    Hello
    rakshith
    You may refer to table 'STM32F070xB/6 pin definitions' in the
    http://www.st.com/content/ccc/resource/technical/document/datasheet/31/4f/10/5f/a5/32/46/42/DM00141pdf/files/DM00141pdf/jcr:content/translations/en.DM00141pdf
    to get the I/O structure.
    Khouloud.
    Andrew Neil
    Posted on April 12, 2018 at 15:49
    See also section 6.3.14,  'I/O port characteristics' in the same document.
