Siragh ASUTP
How to determine from which channel the capture took place?
  • May 1, 2017
  • 4 replies
  • 1064 views
Posted on May 01, 2017 at 08:06
Hello. I use stm32a4 and timer2 (channel 3 and channel 4) in capture mode. How to determine from which channel the capture took place?
    May 1, 2017
    Posted on May 01, 2017 at 18:11
    Check the TIMx->SR it flags which channel(s) captured.
    Use the TIMx->SR = ~CLEARTHISBIT; // not the &= RMW form
    void TIM2_IRQHandler(void)
    if(TIM_GetITStatus(TIM2, TIM_IT_CC3) == SET)
    TIM_ClearITPendingBit(TIM2, TIM_IT_CC3);
    Cap3 = TIM_GetCapture3(TIM2);
    if(TIM_GetITStatus(TIM2, TIM_IT_CC4) == SET)
    TIM_ClearITPendingBit(TIM2, TIM_IT_CC4);
    Cap4 = TIM_GetCapture4(TIM2);
    May 1, 2017
    Posted on May 01, 2017 at 18:12
    Duplicate Thread
    https://community.st.com/0D50X00009XkdeMSAR
    Siragh ASUTP
    Posted on May 16, 2017 at 06:22
    Thanks for the answer. I use the HAL library. Can you give an example for this library?
    May 16, 2017
    Posted on May 16, 2017 at 18:46
    No
