How to detect STM32H573I-DK link status by HAL_ETH_ReadPHYRegister?
Hi supporter,
I'm developing STM32H573I-DK and trying HAL_ETH_ReadPHYRegister to check link status. But this API seems be changed.
Previous prototype is:
HAL_StatusTypeDef HAL_ETH_ReadPHYRegister(ETH_HandleTypeDef *heth, uint16_t PHYReg, uint32_t *RegValue)
But now is:
HAL_StatusTypeDef HAL_ETH_ReadPHYRegister(ETH_HandleTypeDef *heth, uint32_t PHYAddr, uint32_t PHYReg,uint32_t *pRegValue)
I have no idea what PHYAddr is. And PHY_BSR is also not defined in STM32H5. So, I don't know how to fill PHYReg.
Is there any example?
I've referenced to GitHub - STMicroelectronics/STM32CubeH5.
But there are no examples about this API. Thanks for your help.
EyckHuangBest answer
Hi all,
I found that the Ethernet chip on STM32H573I-DK is LAN8742A. So, I referenced document and understood the registers map.
HAL_ETH_ReadPHYRegister(&heth, 0, 1, &tempReg)
where 1 is Basic Status Register and Bit 3 is Link Status.
But I don't know why PHYAddr is 0.
Hope this can help others.
EyckHuangAuthorBest answer
Hi all,
Pavel A.
April 11, 2024
IIRC the "PHY address" is documented in the PHY chip datasheet. Otherwise you can scan all 32 addresses and find who responds.
