l90mehdi
How To Design Best Power Supply Filter for STM32F405 ??????????
  • June 2, 2017
  • 873 views
Posted on June 02, 2017 at 17:09
Hi Dears
I use STM32F405 as MicroController and I have some problem in hardware.
For example i design a circuit with STM32F405 and i supplied it with HI-LINK power supply module.
When I connect some devices into a power outlet ? microcontroller does unwanted things but it dosent RESET.
I putted some filters that contain capacitors and inductors.
I changed my clock source and i reduced the system core clock
I use 16 MHZ oscillator to increase stability.
But the problem is not resolved.
so
How can i resolve this problem???????????
thank you
#filter #stm32-power-suplly-filter #power-supply-filter #stm32-power-supply
    AVI-crak
    Senior
    June 2, 2017
    Posted on June 02, 2017 at 17:46
    The response requires an electrical circuit of the device, and a block program structure (draw cubes).
    Psychics on vacation.
    Zt Liu
    Senior III
    June 3, 2017
    Posted on June 03, 2017 at 10:14
    1. Which hi-link module? I just have some of them.
    2. If you simply use a power supply directly to MCU, does it work?
    3. check Reset pin
    4. make sure the mcu is still alive.
