kostyak
How to count cycles with the ARM simulator
  • July 17, 2008
  • 3 replies
  • 912 views
Posted on July 17, 2008 at 17:02
    16-32micros
    Posted on May 17, 2011 at 12:23
    Hello Manfred,
    I've tried the same and sometimes a get some trouble with Keil simulator and I think that it is not reliable with some instructions like STR and LDR. This discussion has pointed this, some time ago :
    http://www.st.com/mcu/forums-cat-6133-23.html&start=30
    You can simply use the systick counter on real evaluation board of STM32 It is more accurate and can provide you the exact CPU cycles for your becnhmark routines. Regards STOne-32
    kostyak
    kostyakAuthor
    Hi !
    How can I count execution cycles with the Keil MDK ?
    How can I do this with the simulator. Is the simulator
    count reliable ?
    I'm using the STM32 Keil Board.
    regards
    Manfred
    john
    How would you use the systick to count CPU cycles ?
    Would this work over a STOP mode (ie. no cycles are counted) ?
    Thanks,
    John.
