How to configure a parallel synchronous communication through the GPIO interface (using the embedded DMA IP) with cube MX
I don't find how to configure this DMA mode with CubeMx. This mode seems not mentioned in AN4031 (application note for DMA controler).
I want to implement it on a nucleo F429ZI board. I'm working with CubeMx + TrueStudio.
Best
