frank chen
Dec 20, 2017 3:45 AM UTC
How to config ADC ports for B-EMF detection with ST MC WB?
Posted on December 20, 2017 at 04:45
For Motor controller design using FOC sensorless prototype, there are 3 B-EMF signals need to be monitored by MCU. So I shall config 3 ADC channels for this purpose. But with ST MC WB there is no way to do this. what can I do?
Bellow is my schematic.
U, V, W are 3-phase output to drive motor directly. R6, R8 and R10 provide B-EMF signals,  and distribute voltages on R8, R13 and R21 seperately , filtered and smoothed by C1, C5, and C12, clamped on 0.6V by D4ã€�D6ã€�D7,finally connect to Pin 18, 19 and 22 of STM32F302C8, to detect the 0-cross of 3 B-EMF signals.
    AvaTar
    Senior III
    Dec 20, 2017 7:56 AM UTC
    Posted on December 20, 2017 at 08:56
    There are 3 B-EMF signal need to monitored by MCU - STM32F302C8. So I need to config 3 ADCs for this purpose.
    So why not using a F303 with 3 or 4 ADCs ?
    frank chen
    Dec 21, 2017 6:55 AM UTC
    Posted on December 21, 2017 at 06:55
    I've updated my question that it is sofware tool problem. But thanks anyway.
    AvaTar
    Senior III
    Dec 21, 2017 8:42 AM UTC
    Posted on December 21, 2017 at 08:42
    This is not good style, because it puts the answers seemingly out of context.
    Rather post your refined question as follow-up.
    Don't know 'ST MC WB', presumably a 'motor control workbench'.
    And I'm not sure if the F3 is the right choice.
    This ADC peripherals of this series can only be coupled to a dual-mode.
    The F4 series features a triple mode, where all three ADC's virtually operate as one.
    That comes into play if you need full speed of more than 1 Msps.
    If you stay significantly below the ADC's limit, you could get away with one ADC, and a sequential conversion of three channels.
    The usual precautions (hardware design) apply, or you might destroy the controller.
    But for the software, you can either try ST's HAL/Cube, or consult the reference manuals and write it yourself.
    I don't comment on the former.
