MS.11
Mar 30, 2021 6:36 AM UTC
How to check the GPRS HTTP commands in stm32 using UART
May I know how to check the GPRS HTTP commands are continuously working or not in stm32f103c8T6 using UART and How to put those HTTP commands in while loop. Plz help me how to do this.
Thank you
Andrew Neil
Mar 30, 2021 9:44 AM UTC
Not sure what you're asking here?
AT Commands are just text strings - so your first step must be to get sending & receiving text strings working.
You should do that without the GPRS unit; that's just an unnecessary unknown to start with - instead, work with a terminal app on a PC.
To find what AT commands are available, and how to use them, you will need to study the documentation for your particular GPRS module.
Again, spend time with just the module and a terminal app on a PC to get to know and understand the AT commands and how they work.
Don't move on to the microcontroller until you have that firmly understood.
See: https://community.st.com/s/question/0D53W00000eu8lFSAQ/quectel-gsmgprs-at-command
MS.11
MS.11Author
Mar 30, 2021 10:52 AM UTC
Thank You
