cellulenumerique
how to capture signal at rate 3 mbit/s
  • December 9, 2011
  • 4 replies
  • 1020 views
Posted on December 09, 2011 at 23:23
hi,
i have a signal to rate at 3mbit/s. The clock and signal are separate on two line.
i tried to use connect EXTI on the clock. When i have a interrupt, i read the PIN where the signal's. This solution don't work.
So, i want tu use the TIM external clock, and Input capture for read my signal. but this solution is more complicated.
have you other idea?
    December 9, 2011
    Posted on December 09, 2011 at 23:38
    SPI Slave, or Synchronous USART
    cellulenumerique
    Posted on December 10, 2011 at 10:18
    My signal is continus and isn't a SPI format. is it possible to use the periph SPI for other signal type?
     if i use the synchronous USART,
    the
    start bit and
    stop
    going to
    bother me
    because my
    signal
    will not have
    the right structure
    December 10, 2011
    Posted on December 10, 2011 at 14:17
    You say you have a clock and data signal, would seem like a good fit. Perhaps you need to be more specific.
    cellulenumerique
    Posted on December 10, 2011 at 22:40
    I read more the datasheet and i think your solution is good.
    I will tried this solution, monday.
