frank5
Feb 22, 2009 11:09 AM UTC
How to, 9bit SPI for a LCD
Posted on February 22, 2009 at 12:09
    frank5
    frank5Author
    May 17, 2011 10:52 AM UTC
    Posted on May 17, 2011 at 12:52
    I finally made it work using the 16bit spi and using in the MSB, the 9bits used.
    It was a worng initiliazation sequence that I did wrong and it didn't work in the first place.
    So I can now confirm that this lcd controller ignores the rest 7 bits sent.
    Frank
    philippe239955
    Hi Frank,
    Thanks to you I managed to use the LCD :-]
    Thank you again !
    Kind regards
    frank5
    frank5Author
    Hi Philippe,
    Source code to drive this LCD can be found here:
    http://gravitech.us/MicroResearch/Others/LCD6100/LCD6610_NPX_STM32F103.zip
    Frank
