Peko
How send answer on UDP server ?
I created UDP server with LwIP stack on STM32F407.
I tried example udp_echo _server. It works.
Now I need send from server my own answer data in callback function.
The program hangs in callback function.
void udp_echoserver_receive_callback(void *arg, struct udp_pcb *upcb, struct pbuf *p, const ip_addr_t *addr, u16_t port)
	unsigned char buffer[80] = "my name is xxxxxxx";
	p = pbuf_alloc(PBUF_TRANSPORT,100, PBUF_RAM);
	p->payload = buffer;
 p->len = p->tot_len = 20;
	/* Connect to the remote client */
	udp_connect(upcb, addr, UDP_CLIENT_PORT);
	/* Tell the client that we have accepted it */
	udp_send(upcb, p);
 /* free the UDP connection, so we can accept new clients */
 udp_disconnect(upcb);
 /* Free the p buffer */
 pbuf_free(p);
What is wrong ?
Is somewhere on web LwIP stack guide?
Thank you
    Explorer
    January 11, 2025
    Replace thease lines:
        p->pauload = buffer;
        p-<len = p->tot_len = 20;
    with theases:
        /* copy data to pbuf */
        pbuf_take(p, (char*)buffer, strlen(buffer));
