Fkasa.1
How many interrupt by an exception having higher priority can be executed?
The execution of an interrupt handler can be preempted by an exception having higher priority.
In the link below, two interrupts are generated. Is this number infinite?
TDKBest answer
April 15, 2022
There are up to 16 different preemption priorities available, so effectively 16.
There are additional higher priority levels beyond this (e.g. hard fault), but generally are not in use.
TDKBest answer
April 15, 2022
Fkasa.1
Fkasa.1Author
Thank you for your reply.
We consider  interrupt can be preempted 16 times.
