CHan.2
How do I implement TCP/IP on the F746NG-Disco?
I referred to the example of 1.16.1 of F746G.
The contents of MPU_Config() and System Clock_Config() have been copied. Ping test failed after applying rtOS (Stack Size = 256) and LWIP.
The example is ping test, so there is no problem with the configuration.
How to make Project?​
