john doe
Senior III
Apr 3, 2017 3:07 AM UTC
How do I get there from here? Hex to Ascii from struct field
Posted on April 03, 2017 at 05:07
I've been playing with the hal sd card driver today.
printf(' Product name : %lx%x\r\n', pSD_CID_Info.ProdName1, pSD_CID_Info.ProdName2);
where pSD_CID_Info is of the type HAL_SD_CardCIDTypeDef which is
typedef struct
  __IO uint8_t  ManufacturerID;  /*!< Manufacturer ID       */
  __IO uint16_t OEM_AppliID;     /*!< OEM/Application ID    */
  __IO uint32_t ProdName1;       /*!< Product Name part1    */
  __IO uint8_t  ProdName2;       /*!< Product Name part2    */
  __IO uint8_t  ProdRev;         /*!< Product Revision      */
  __IO uint32_t ProdSN;          /*!< Product Serial Number */
  __IO uint8_t  Reserved1;       /*!< Reserved1             */
  __IO uint16_t ManufactDate;    /*!< Manufacturing Date    */
  __IO uint8_t  CID_CRC;         /*!< CID CRC               */
  __IO uint8_t  Reserved2;       /*!< Always 1              */
}HAL_SD_CardCIDTypeDef;
the output is
 Product name : 5355303447
but the 0x5355303447 when converted to ascii should read
Product name : SU04G
how do I get there from here?
    Tesla DeLoreanBest answer
    Apr 3, 2017 4:32 AM UTC
    Posted on April 03, 2017 at 06:32
    printf(' Product name : %-5s\r\n', &pSD_CID_Info.ProdName1);
    { // perhaps safer
    char string[6] = { 0 };
    memcpy(string, &pSD_CID_Info.ProdName1, 5);
    printf(' Product name : %s\r\n', string);
    char *p = (char *)&pSD_CID_Info.ProdName1;
    printf('%c%c%c%c%c\r\n',p[3],p[2],p[1],p[0],p[4]); // Endians as described in your example
    printf('%c%c%c%c%c\r\n',p[0],p[1],p[2],p[3],p[4]);
    { // perhaps safer
