How can I include HAL Legacy Can drivers instead of the updated HAL CAN Driver
I inherited a Keil Project which used the HAL Legacy CAN driver, and so I'm trying to port this system to SW4STM32, however, when I generate/regenerate a new project with the STM32Cube Generator, the CAN driver is replaced.
Normally this wouldn't be an issue, except we heavily use the CAN structures, which no longer exist, so it would be quite an impediment to need to upgrade the CAN driver just to move out of the Keil Ecosystem. Are there any suggestions or work arounds so that I can continue using the Legacy CAN driver with STM32Cube.
