mrsmile
Jun 6, 2023 1:56 PM UTC
How can I enable TDR register and Five bytes data transmit in UART_DMA?
Hi, I am using STM32G030K6T6 Microcontroller. I need a help for how can i Enable TDR Register and handle the interrupt handler. interrupt handler does not run and I need is Five Bytes data transmit in Uart_DMA. But registers does not wrk properly. I made a mistake anywhere please guide me. I include my code.
#include "main.h"
/* USER CODE BEGIN PV */
uint32_t data[5]={0x00,0x01,0x03,0x05,0x02}; uint16_t tim=0;
/* USER CODE END PV */
/* USER CODE BEGIN PFP */
void Tim3_Init(void)
	RCC->APBENR1 |= RCC_APBENR1_TIM3EN; // TIM3 timer clock enable
	TIM3->PSC = 2;
	TIM3->ARR = 22999;
	TIM3->CNT = 0;
	TIM3->DIER |= TIM_DIER_UIE; //Update interrupt enable
	NVIC_EnableIRQ(TIM3_IRQn); //Interrupt enable
	TIM3->CR1 |=TIM_CR1_CEN; //COUNTER ENABLE
	TIM3->EGR |= TIM_EGR_UG; //Update generation
void UART2_Init(void)
	RCC->APBENR1 |= RCC_APBENR1_USART2EN; // USART2 clock enable
	RCC->IOPENR |= RCC_IOPENR_GPIOAEN; // I/O port A clock enable
	GPIOA->MODER &= ~(GPIO_MODER_MODE2); // clear 2th pin
	GPIOA->MODER |= (GPIO_MODER_MODE2_1); // 10: Alternate function mode
	GPIOA->MODER &= ~(GPIO_MODER_MODE3); // clear 3th pin
	GPIOA->MODER |= (GPIO_MODER_MODE3_1); // 10: Alternate function mode
	GPIOA->AFR[0];
	GPIOA->OTYPER |= (0<<2); // output_pushpull
	USART2->CR1 |= USART_CR1_TE;
 USART2->CR3 |= USART_CR3_DMAT; // DMA TX_ENABLE FOR USART2
	USART2->BRR |= 0X1D4B; // BAUDRATE
	USART2->CR1 |= USART_CR1_UE; //USART_ENABLE
void DMA_Init(void)
	RCC->AHBENR |= RCC_AHBENR_DMA1EN; //DMA1_MUX_CLK_Enable
//	SYSCFG->IT_LINE_SR = SYSCFG_ITLINE9_SR_DMA1_CH1;
	DMA1_Channel1->CCR |= DMA_CCR_MINC | DMA_CCR_TCIE | DMA_CCR_DIR | DMA_CCR_CIRC | DMA_CCR_TEIE | DMA_CCR_HTIE ; // MEMORY_INC, TX_COMP_INT, DATA_TX_DIR, CIRCULAR_MODE
	DMA1_Channel1->CPAR = (uint32_t)&USART2->TDR;
	DMA1_Channel1->CNDTR=5;
	DMA1_Channel1->CCR|= DMA_CCR_EN;
	NVIC_EnableIRQ(DMA1_Channel1_IRQn);
void tx(char tx_data)
 USART1->TDR= tx_data;
 while(!(USART2->ISR & (1<<6)));
void DMA_transmit(char data, uint8_t size)
		DMA1->IFCR |= DMA_IFCR_CTCIF1; // channel tx complete clear
	 DMA1_Channel1->CMAR =(uint32_t)data;
/* USER CODE END 0 */
 * @brief The application entry point.
 * @retval int
int main(void)
 /* USER CODE BEGIN 1 */
 /* USER CODE END 1 */
 HAL_Init();
 /* USER CODE BEGIN Init */
 /* USER CODE END Init */
 SystemClock_Config();
 /* USER CODE BEGIN SysInit */
 /* USER CODE END SysInit */
 MX_GPIO_Init();
 /* USER CODE BEGIN 2 */
	Tim3_Init();
 UART2_Init();DMA_Init();
 /* USER CODE END 2 */
 /* Infinite loop */
 /* USER CODE BEGIN WHILE */
 while (1)
 /* USER CODE END WHILE */
 /* USER CODE BEGIN 3 */
 /* USER CODE END 3 */
void DMA1_Channel1_IRQHandler(void)
	while((DMA1->ISR & DMA_ISR_TCIF1)==0);
	DMA1->IFCR =DMA_IFCR_CTCIF1; // channel tx complete clear
 * @retval None
void SystemClock_Config(void)
 HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1);
 RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
 RCC_OscInitStruct.HSIState = RCC_HSI_ON;
 RCC_OscInitStruct.HSIDiv = RCC_HSI_DIV1;
 RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
 RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
 RCC_OscInitStruct.PLL.PLLM = RCC_PLLM_DIV1;
 RCC_OscInitStruct.PLL.PLLN = 8;
 RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
 RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2;
 Error_Handler();
 |RCC_CLOCKTYPE_PCLK1;
 RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
 if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
 Error_Handler();
 * @param None
 * @retval None
 /* GPIO Ports Clock Enable */
 __HAL_RCC_GPIOC_CLK_ENABLE();
 __HAL_RCC_GPIOA_CLK_ENABLE();
 /*Configure GPIO pin : PC15 */
 GPIO_InitStruct.Pin = GPIO_PIN_15;
 GPIO_InitStruct.Alternate = GPIO_AF1_OSC;
 HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
void TIM3_IRQHandler(void)
	TIM3->SR &= ~TIM_SR_UIF;
	 tim++;
/* USER CODE END 4 */
 * @brief This function is executed in case of error occurrence.
 * @retval None
void Error_Handler(void)
 __disable_irq();
 while (1)
#ifdef USE_FULL_ASSERT
 * @brief Reports the name of the source file and the source line number
 * where the assert_param error has occurred.
 * @param file: pointer to the source file name
 * @param line: assert_param error line source number
 * @retval None
void assert_failed(uint8_t *file, uint32_t line)
 /* USER CODE BEGIN 6 */
 /* User can add his own implementation to report the file name and line number,
 ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
 /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
