MNapi
Senior II
March 25, 2019
Ho do you connect external oscillator to STM32L412 ?
  • March 25, 2019
  • 4 replies
  • 1354 views
I cannot find any schematics, what kind of crystal. I want to connect 20 MHz. It seems it is as high as it can go. The datasheet does not say exactly what o connect.
Some of the STM have two pins to connect extearnal oscillator but this one has just one pin.
Uwe Bonnes
Chief
March 25, 2019
Connect to PH0-OSC_IN, leave PH1-OSC_OUT open.
David SIORPAES
AN2867 application note can guide you in selecting the proper oscillator.
March 28, 2019
Not going to help if part doesn't bond out OSC_IN/OSC_OUT, and only provides PA0-CK_IN input.
March 28, 2019
Should really review the Data Sheet
fHSE is specified as 48 MHz for Voltage Scaling Range 1, 26 MHz for Range 2
https://www.st.com/resource/en/datasheet/stm32l412k8.pdf
Parts using "CK_IN" expect an XO providing a CMOS level clock signal, ie TCXO
