HElia.2
April 14, 2023
Hi can i just check, are all morpho connectors on 144 pin boards pin compatible?
    Mike_ST
    Mike_STBest answer
    we try to keep some compatibility, at least for power/ground pins.
    But for other pins they are not always the same.
    It is better that you compare the boards you are interresed in by using the schematics.
    Mike_ST
    Mike_STBest answer
