May 21, 2026 10:28 PM UTC
Help on STM32H753VIH6
Can someone pls help me fill this information out for STM32H753VIH6? Thank you.
Model Name
Check Group
1 (注1)
2 (注2)
3 (注3)
4 (注5)
Ministerial Ordinance Article Number
第6条第一号イ
第6条第一号ロ
第6条第一号ハ
Check Items
Presence or Absence of Radiation-Hardened Design
Design Intent
Rated Operating Temperature Range (°C)
Whether or not compound semiconductors are used (Note 4)
Maximum Clock Frequency (Note 4) (MHz)
Determination Criteria
(i) Total Ionizing Dose: (Applicable) ≧ 5x10³ Gray (Si)
(ii) Dose Rate: (Applicable) ≧ 5x10⁶ Gray (Si)/s
(iii) Neutron Flux (1 MeV equivalent): (Applicable) ≧ 5x10¹³ (particles/cm²)
Is it designed for civil automobiles or railway vehicles?
(i) (Applicable) > 125°C
(ii) (Applicable) < -55°C
(iii) (Applicable) = -55 to 125°C
(Applicable) = Formed from compound semiconductors
(Applicable) > 40
(Filling Example) ABCxxxxx
No
0~85
(Compound)
30
STM32H753VIH6
Model Name
Check Group
1(注1)
2(注2)
3(注3)
4 (注4)
第6条第一号イ
第6条第一号ロ
第6条第一号ホ(一)
1
2
3
4
5
Check Items
Design Intent
Resolution (bit)
<10bit  resolution
8bit≦
<12bit resolution
10bit≦
<14bit resolution
12bit≦
<16bit resolution
14bit≦
resolution 16bit≦
Sampling
rate
Sampling
rate
Sampling
rate
Sampling
rate
Sampling
rate
(該)≧5x10⁶ グレイ(Si)/s
>1.3
(Giga samples/sec)
>600
(Mega samples/sec)
>400
(Mega samples/sec)
>250
(Mega samples/sec)
>65
(Mega samples/sec)
(example)ABCxxxxx
No
0~85
10
150
STM32H753VIH6
Andrew Neil
May 22, 2026 8:09 AM UTC
Many (most?) of those things will be in the datasheet; eg, operating temperature range, maximum frequencies.
https://www.st.com/en/microcontrollers-microprocessors/stm32h753vi.html#documentation
KDJEM.1
May 22, 2026 1:31 PM UTC
Hello @jamieguinto and welcome to the community;
Could you please look at How to write your question to maximize your chance... - STMicroelectronics Community and give more details about your issue or request.
Thank you.
Kaouthar
