matthias2
Sep 13, 2013 9:39 AM UTC
Help needed to layout stack and heap on a STM32 F0
Posted on September 13, 2013 at 11:39
I'm doing my first project with the STM32F051x8. Yesterday may code was not running in cause of heap problems.
I played around with the 'startup_stm32f0xx.s' file, set different sizes for Stack_Size, HeapSize.
Can anyone explain to me where Stack and Heap is placed too?
What are the limits for Heap_Size and Stack_Size?
Matt
    Sep 13, 2013 11:03 AM UTC
    Posted on September 13, 2013 at 13:03
    Using Keil?
    To see where they are placed, look at the .MAP file, typically they are place at the end-of-ram consumed by your other statically allocated variables. The limitation on combined size of statics + heap + stack is thus you available RAM (often IRAM1 per the Target Pane under options, or Scatter File)
    matthias2
    matthias2Author
    Sep 13, 2013 2:16 PM UTC
    Posted on September 13, 2013 at 16:16
    Yes, I'm using Keil.
    Thanks for the help. Code is now running.
