OIoni.1
Hello! What is the difference between output compare and output compare no output in Cube IDE? Can I use output compare no output to trigger ADC?
  • June 26, 2021
  • 953 views
No output means the signal isn't piped out to a pin, but everything else happens, so yes you can still use it to trigger the ADC.
OIoni.1
OIoni.1Author
Thank you!
