JPann.1
Apr 21, 2023 5:37 PM UTC
Hello, I use STM32F469I-DISCO-REV-AU1 and want to connect RTC DS3231 as my external clock. I am trying to connect. I tried to connect using I2C but couldn't get any response on the screen after this. Can anyone help me with this?
Pavel A.
Apr 21, 2023 6:27 PM UTC
STM32469? Do you have this board?
JPann.1
JPann.1Author
Apr 21, 2023 6:30 PM UTC
its STM32F469I-DISCO-REV-AU1
Pavel A.
Apr 21, 2023 8:23 PM UTC
So the RTC is attached to the I2C connector on the board, correct?
Have you tried to debug? Do you know how to use the debugger?
Apr 21, 2023 9:40 PM UTC
Show Code, Show Wiring...
Should be able to use I2C on D14(SDA)/D15(SCL) and GND from shield connector.
ST uses LEFT aligned 7-bit I2C addresses, so (addr << 1) compared to Arduino sketches
