eugene239955
Jan 12, 2018 11:04 PM UTC
Hello, i'm trying to generate 3ph pwm sinewaves using dma, sine lookup table and timer1.
Posted on January 13, 2018 at 00:04
I working with a nucleo-f410rb and atollic truestudio along with cubemx. I can get a channel1 (or 2 or 3) of timer1 to work using HAL_TIM_PWM_Start_DMA but i can not get the three to work together. I've tried using  HAL_TIM_DMABurst_WriteStart by constructing a sine lookup table holding n pairs of three PWM values and trying to
HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_1);
HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_2);
HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_3);
HAL_TIM_DMABurst_WriteStart(&htim1, TIM_DMABASE_CCR1, TIM_DMA_UPDATE, (uint32_t *)tab_a, TIM_DMABURSTLENGTH_3TRANSFERS);
where tab_a holds the values for CCR1,2,3.
Can this be done (3 phase pwm sine waves) ? I seem to be missing something basic here.
Thanks,
Gene
    T J
    Senior III
    Jan 14, 2018 9:33 PM UTC
    Posted on January 14, 2018 at 22:33
    if you want to adjust 3x PWM signals,
    under a different timer interrupt with high priority, say every 100uS, write all three PWM values. from your sinewave table.
    easier without a DMA,
    to use a DMA, you would use a circular buffer for the whole table, but you only have one pointer per DMA
    now you need 3 DMAs ?
