JWang.29
Hello, I am connecting a DHT22 temperature sensor to STM32F103C8T6 microcontroller. I am using HAL and reading temperature and humidity data from serial uart, on a terminal on my PC.
Please assist on how to resolve this. because if I deploy in the field it is not possible to be hard resetting every time for data to start streaming.
Thank you.
Karl Yamashita
Principal
November 26, 2024
You haven't indicated exactly what the issue is
