Nov 8, 2026 7:27 AM UTC
Having Trouble Understanding How to Choose the Right STM32 Microcontroller
Hi everyone,
I'm relatively new to working with STM32 microcontrollers and still learning how to choose the right board for different projects.
I've been looking at several STM32 models, but I'm a little confused about the differences in memory, processing power, and available peripherals.
How do you usually decide which STM32 microcontroller is suitable for a particular project? Are there any important specifications that beginners should check before making a choice?
I'd also appreciate any suggestions for useful documentation or beginner-friendly resources.
Thanks for sharing your experience!
AScha.3
AScha.3Best answer
Nov 8, 2026 6:04 PM UTC
is more:
How to decide which microcontroller is suitable for a particular project?
  1. write down all you need definitely (UARTs, SPI, I2C, CAN, USB, etc...)
  2. guess how big will the program be , take + 100%, for future buffer
  3. guess needed speed (hi speed data coming in, or not...etc.)
  4. check the avail money for the controller - if possible, choose a faster/bigger/expensive one
  5. check how many I/O and ports for functions you need (add same buffer), then you know the pins you need
Now search in mouser or ST selection table for something, that fits all needed parameters, or is bigger/faster..whatever
https://www.st.com/content/st_com/en/stm32-mcu-product-selector.html
https://www.mouser.de/de/c/semiconductors/embedded-processors-controllers/microcontrollers-mcu/arm-microcontrollers-mcu/
Nov 8, 2026 12:11 PM UTC
It depends on your application. What's the particular project that you are working on?
AScha.3
AScha.3Best answer
is more:
David Littell
Senior II
Nov 9, 2026 12:58 AM UTC
  1. Make sure a Nucleo board is available for the chosen MCU (or something close) so you can do some prototyping to determine if you made good choices.  If successful, use the Nucleo and the stuff you hang from it as a reference design.
Andrew Neil
Nov 9, 2026 8:33 AM UTC
Welcome to the forum.
Do you have experience with any other microcontroller(s)? With (embedded) development in general?
The way you choose an STM32 is no different to the way you’d choose any other microcontroller - or, in fact, any other component:
  1. Consider the requirements of your system
  2. Look for a part which meets those requirements
Of course, as with any engineering project, there will be compromises - so you’ll have to decide what gives the best tradeoff given your specific set of requirements and constraints.
If in doubt, go for the option which give you more than you think you’ll need - more speed, more memory, more ports, etc.
It is far easier to optimise down to a “smaller” part once you have something working than to get stuck with nothing working because you chose something too “small”.
Expect this to be an iterative process.
As ​@David Littell said, test things out on eval boards - I second the suggestion of Nucleo boards.
In addition to ​@AScha.3’s list of things, another important consideration is your own capabilities - don’t jump straight into an over-complicated project using an over-complicated part which is beyond you.
Start simple; work up step-by-step.
There’s an overview of the complete STM32 portfolio here:
https://www.st.com/en/microcontrollers-microprocessors/stm32-32-bit-arm-cortex-mcus.html
As ​@AScha.3 said, there’s a selection tool here:
dial-in your requirements, and it will list parts which meet those criteria.
As he said, Distributors also have their own parametric search tools.
You could also ask Sidekick - ST’s own AI, focussed specifically on STM32 technical questions:
Ozone
Principal
Nov 9, 2026 8:46 AM UTC
> I'm relatively new to working with STM32 microcontrollers  …
Then ditch the H7 series as suggested by the tag, and start with a M0/M0+, which is much less complex.
I think you have a choice here.
Either you go with the “beginner-friendly and easy” route, and learn to use CubeMX and other automated tools.
But you will learn very little about the MCUs itself (unless bugs force you to).
The other option are the datasheet and the reference manuals, that tell you everything about a MCU you need to know. And perhaps some application notes and erratas.
But those take some time to diggest.
Basically, IO channel, performance and resource requirements of your project.
The more specific the project description is, the better we can narrow down the best-fitting MCU.
EmoliaaveAuthor
Nov 9, 2026 9:43 AM UTC
AScha.3
Thnks for help
