igor2399
Hard Fault problem
  • March 23, 2011
  • 5 replies
  • 1101 views
Posted on March 23, 2011 at 10:10
Hard Fault problem
    igor2399
    igor2399Author
    Posted on May 17, 2011 at 14:29
    May 17, 2011
    08002ace:   str r2, [r3, #0] << Could it be faulting here. What is in R3?
    May 17, 2011
    No problem, you'll catch it the next time.
    NULL or invalid pointers are a classic cause of Hard Faults, and the address you were pointing to looked just fine. So I looked at the next most likely reason.
    Was Atollic pointing you at this address, or do you have some fault handler code, like Joseph Yiu's example?
    igor2399
    igor2399Author
    Yes, the problem was that!
    There was an uninitialized pointer :(
    And it wasn't signaled by the IDE!! :( :(
    I did a lot of noise for a stupid problem... Sorry!
    Thaks Clive1 for the illuminating hint! :)
    I.
    igor2399
    igor2399Author
