Review the processor registers and assembler instructions at the fault to get a better idea of what the cause might be.
Generally will be issues accessing memory, either memory that doesn't exist or alignment issues. Check things like stack size, potential corruption on stack. Make sure not to link 32-bit code into the project.
Do you have a teacher, colleague or supervisor who can work with you on these things?
