e d
Jun 26, 2017 7:21 PM UTC
Handling flash double word 64-bit programming
Posted on June 26, 2017 at 21:21
Hi all,
I am working with the STM32L486 series and having a flash question. I need to save some NVM parameters to a 2K page in flash but the flash utils can only write double word at a time (64 bits). My NVM structure size will ebb and flow and would probably not align to a 64-bit boundary. How do I handle saving the structure gracefully in the code? I am thinking of padding some dummy bytes to meet the 64-bit boundary but it is a bit cumbersome. I used to do this feature in bytes easily when working with other processors capable of byte write, but this is a bit different. Any ideas?
Thanks,
ED
    Jun 26, 2017 7:39 PM UTC
    Posted on June 26, 2017 at 21:39
    Can you just not use a struct, where you memcpy from FLASH to RAM, or read in-place, and then have a writing routine that commits the whole thing, rounded to an 8-byte boundary, from a RAM based buffer? Or malloc() the RAM buffer rounded up to the next 8-byte size, and access via a pointer.
    I don't see a fault occurring unless the structure is pushed to the very top of RAM so not padding exists, but the stack is most likely there.
    e d
    e dAuthor
    Jun 26, 2017 10:21 PM UTC
    Posted on June 26, 2017 at 22:21
    Thanks Clive for the quick response, as always. I'd like to use a master RAM based NVM struct, which consists of a few sub structs, to do one shot memcpy as you mentioned. This contributes to the code clarity and efficiency, which are important to me.
    Been thinking maybe I need to align all the sub structs to a 64-bit boundary. The unused bytes will be designated as spares to be replaced with actual parameters when a particular sub struct needs to expand. For example:
    typedef struct NVM_STRUCT_ID
          uint16_t Param1;
          uint16_t
    Param2
          uint16_t
    Param3
    uint16_t
    Param4
    uint16_t
    Param5
    uint16_t
    spare1
    uint16_t
    spare2
    uint16_t
    spare3
    } NVM_STRUCT_ID;
    Of course the spares will be managed at a minimum to minimize foot print.
    Will experiment a few methods as I go along.
    misagh
    Jun 27, 2017 7:26 AM UTC
    Posted on June 27, 2017 at 07:26
    I usually prefer to pass the memory alignment to compiler by using unions. For example:
    typedef struct MY_STRUCT
     uint16_t Param1;
     uint16_t Param2;
     uint16_t Param3;
    } MY_STRUCT;
    union{
     uint64_t u64;
     MY_STRUCT id;
    }testunion;
    uint64_t test64;
    testunion.id.Param1 = 1;
    testunion.id.Param2 = 2;
    testunion.id.Param3 = 3;
    test64 = testunion.u64; // converted NVM_STRUCT_ID to 64-bit variable�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?
    Bests,
    Misagh
