matteo239955_st
HAL_TIM_OnePulse_Start_IT Any example?
Posted on November 23, 2015 at 08:37
Hi, someone have any example for this type of TIM function?
#stm32-tim
Amel NASRI
Posted on November 23, 2015 at 16:24
Hibandini.matteo,
There is an example with polling not IT underSTM32Cube_FW_F4_V1.9.0\Projects\STM324x9I_EVAL\Examples\TIM\TIM_OnePulse.As per
https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Create%20a%20precision%20timer%20with%20HAL%20and%20interrupt
, I think that you are using F0 device.
It will be possible to get the idea from the example I provided and update the CubeMX generated code accordingly.
-Mayla-
matteo239955_st
Posted on November 24, 2015 at 12:48
Hi, if I need a Interrupt at the end of the pulse what I need to activate?
If I want to change the pulse period every pulse what I need to do?
Thank you very much.
