ian ringheim
May 26, 2017
HAL_TIM_OnePulse driver output channel limitation.
  • May 26, 2017
  • 698 views
Posted on May 26, 2017 at 14:59
I don't understand why there is a limitation on output channel that can be used in driver in OnePulse mode.
HAL_TIM_OnePulse_ Start specifies that only CH1 or CH2 can be used as output. Why cant other channels be used as output?
I understand why CH1 or CH2 has to be used as input.
#one-pulse #stm32l4-timer
waclawek.jan
Posted on May 26, 2017 at 15:44
Which mcu, which timer?
Technical Moderator
May 26, 2017
Posted on May 26, 2017 at 16:04
Hi
ringheim.ian
Which firmware version are you using ?
