Filipx.87
Mar 24, 2023 9:18 PM UTC
HAL I2C timeout flag
I have a simple function that reads one byte from I2C and I need the RxdFlag variable to be cleared in case of unsuccessful transfer (timeout) and I don't know how to get it from the HAL_StatusTypeDef structure. Thanx for your help.
uint8_t GetSlaveInfo (uint8_t *value)
 uint8_t RxdFlag = 1;
 HAL_I2C_Master_Receive(&hi2c1, EE_I2C_ADDR << 1, value, 1, 50);
 return RxdFlag;
Pavel A.
Pavel A.Best answer
Mar 25, 2023 5:49 AM UTC
 uint8_t RxdFlag = 0;
 HAL_StatusTypeDef st =
 if (st == HAL_OK)
 RxdFlag = 1;
 return RxdFlag;
What should your function return in case of other errors besides of timeout?
Pavel A.
Pavel A.Best answer
 if (st == HAL_OK)
 RxdFlag = 1;
 return RxdFlag;
Piranha
Principal III
Mar 25, 2023 5:18 PM UTC
uint8_t GetSlaveInfo(uint8_t *value)
	HAL_StatusTypeDef st = HAL_I2C_Master_Receive(&hi2c1, EE_I2C_ADDR << 1, value, 1, 50);
	return (st == HAL_OK);
	return (HAL_I2C_Master_Receive(&hi2c1, EE_I2C_ADDR << 1, value, 1, 50) == HAL_OK);
 Often I don't understand why people write so much useless code...
