Sandeep Dhokne
Jul 14, 2017 9:52 AM UTC
HAL I2C Communication Problem
Posted on July 14, 2017 at 11:52
Dear Sir/Madam,
I am working on STM32F405 mcu.
I developed my code on cubemx and HAL drivers.
I want to interface microchip adc 'MCP3428' via HAL I2C drivers but unfortunately i was failed.
Anybody of you please help me to resolved this issue.
Thank you.
    john doe
    john doeBest answer
    Senior III
    Jul 14, 2017 5:45 PM UTC
    Posted on July 14, 2017 at 19:45
            status = HAL_I2C_Mem_Write(&hi2c1,                        // i2c handle
                                  (uint16_t)(dev_addr<<1),        // i2c address, left aligned
                                  (uint8_t)reg_addr,            // register address
                                  I2C_MEMADD_SIZE_8BIT,            //  8bit register addresses
                                  (uint8_t*)(&reg_data),        // write returned data to variable named reg_data
                                  cnt,                            // write how many bytes
                                  100);                            // timeout
    you'll have to read your data sheet for addresses and sizes, but the above code is how to read a register
    john doe
    john doeBest answer
    Senior III
                                  100);                            // timeout
    Sandeep Dhokne
    Jul 17, 2017 11:39 AM UTC
    Posted on July 17, 2017 at 11:39
    Thank you so much.
    My problem is solved.
