SRehm.2
Jul 19, 2022 2:34 PM UTC
((HAL_GPIO_ReadPin(GPIOA, GPIO_PIN_10) == GPIO_PIN_SET) ? 1:0); I am using this command to read a pin, Actually it is Arduino format. So I want to ask if this works in ST as well and if the same syntax work does it read both 1 and 0?
Peter BENSCH
Peter BENSCHBest answer
Aug 19, 2022 6:54 AM UTC
Welcome, @SRehm.2​, to the community!
We're sorry that the answer took a little while to come:
The condition mentioned is called a ternary operator, not specific to Arduino, which is based on C++, but also available in C. If you wanted to use this for the assignment to a variable, you can use it exactly like this.
Does it answer your question?
/Peter
Peter BENSCH
/Peter
Piranha
Principal III
Oct 5, 2022 1:54 AM UTC
That code is written by someone, who doesn't know the C/C++ languages, because the following code does exactly the same:
(HAL_GPIO_ReadPin(GPIOA, GPIO_PIN_10) == GPIO_PIN_SET);
But it's safer and more efficient to convert it to this:
(HAL_GPIO_ReadPin(GPIOA, GPIO_PIN_10) != GPIO_PIN_RESET);
