HAL function to generate an I2C software reset on the bus
I sometimes have a problem during debugging, that after reset the Eeprom connected to I2C bus does not respond any more.
I assume that the reason might be that I reset my system during a running I2C communication - leaving the bus in an indeterminate state (kept by the Eeprom device).
There are examples for creating a sort of "software reset" on the bus by sending a couple of bits on the bus until the bus is released.
My question: is there a HAL or LL function that will provide such a functionality? Or will I really need to do this by bit banging?
