GPIO pin max current input (sink)
I want to use led with following connection and i remember that I've seen this application somewhere on the Internet:
3V3 - LED - RESISTOR - STM32 PIN
I've seen the max total current output of MCU then is there any max total input current of MCU?
Andrew Neil
Andrew NeilBest answer
LoL - that is the standard way to use an LED with any microcontroller!
Yes, these figures will be in the Datasheet for the chip - the Electrical Specifications section.
Andrew Neil
yonggeonAuthor
does "injected current" mean input current?
Andrew Neil
I don't think so - context needed.
You are looking for the GPIO pin current sink capacity.
What chip are you using?
