mehmet.karakaya
Sep 20, 2010 8:07 AM UTC
GPIO configuration change takes 25 microsecond
Posted on September 20, 2010 at 10:07
#raisonance
    trevor23
    May 17, 2011 12:07 PM UTC
    Posted on May 17, 2011 at 14:07
    unsigned int is 32 bits on every compiler for ARM I have ever used. I'd be very surprised if it were not as it is a 32 bit core.
    trevor23
    Don't know anything about Ride but you can use this in your code to find out:
    printf( ''sizeof(int) = %u\r\n'', sizeof(int) );
    printf( ''sizeof(char) = %u\r\n'', sizeof(char) );
    printf( ''sizeof(long) = %u\r\n'', sizeof(long) );
    etc.
    At a guess int will be 32 bits, long will be 32 bits, long long will be 64 bits, char will 8 bits, short will be 16 bits.
    mehmet.karakaya
    where can I learn the size of datatypes in RIDE7 ?
    which doc ?
