Apr 8, 2026 11:19 AM UTC
GBW of OPAMP - wider design limits - STM32C5
Any reason why the GBW of the OPAMP is having such a wide tolerance? Is it purely because the values are best-worst case design calculations?
In comparison, the Gx and Fx variants has better limits.
STOne-32
Jun 10, 2026 6:18 PM UTC
Dear  ​@mechatron
Thank you a lot for pointing to this GBW wide tolerance representation in our documentation, after full analysis with our validation and design teams, we confirm an issue on that line and should be:
  • Min : 6MHz
  • Typical : 15MHz
20MHz value is only for No load and should not be there. We are tracking this Change and update with internal reference CDM0063403.   Thank you again and much appreciated.
Regards,
STOne-32
mechatronAuthor
Jun 11, 2026 6:35 AM UTC
Thank you for the detailed response and prompt action. Much appreciated!
