Srinivas Gopal
Feb 13, 2018 4:22 PM UTC
Gas Gauge(STC3115) Initialization on a custom board
Posted on February 13, 2018 at 17:22
I am trying to get STC3115 working on a custom board based on STM32L476VX MCU. The battery used for the custom board is RJD3555. After initializing the I2C interface, the gas gauge always fails to initialize. Any help on this matter would be greatly appreciated
Thanks,
Srinivas
#stm32l4 #stc3115
Andrew Neil
Feb 13, 2018 4:39 PM UTC
Posted on February 13, 2018 at 17:39
http://www.st.com/en/power-management/stc3115.html
So, before starting on your custom board, have you built basic familiarity & functionality with one of the listed evaluation options:
http://www.st.com/content/st_com/en/products/evaluation-tools/solution-evaluation-tools/psu-and-converter-solution-eval-boards/steval-isb014v2.html
http://www.st.com/content/st_com/en/products/evaluation-tools/solution-evaluation-tools/sensor-solution-eval-boards/steval-wesu1.html
So what, exactly, does that mean?
How have you proven basic I2C comms ?
Srinivas Gopal
Feb 13, 2018 6:25 PM UTC
Posted on February 13, 2018 at 18:25
The first I2C communication is for initialization of STC3115, there is no other peripheral connected to the MCU via I2C, Is there a way to test I2C comms before initializing the gas gauge?
Thanks,
Srinivas
Andrew Neil
Feb 13, 2018 6:46 PM UTC
Posted on February 13, 2018 at 18:46
Go on - this is basic I2C stuff.
Have you read and understood chapter 7 of the datasheet - which describes the I2C interface, Register Map, etc ?
  • Does the chip correctly ACK its address?
  • Can you read the ID register?
  • Can you write to a register, and read-back what you wrote?
Have you studied the evaluation resources I linked above?
Have you
studied the support documents on the Product Page, linked above?
