Timo Eggers
Mar 21, 2018 8:01 AM UTC
Freezing the IWGD Watchdog under Debug is not working
Posted on March 21, 2018 at 09:01
i have a STM32F051 and use the independent watchdog.
I would like the IWDG counter to stop if the core is halted.
I set the DBG_IWDG_STOP in the DBG Modul, but when i stop the core with the debuger my mcu still goes in reset.
I tried setting the bit with µVision IDE, with HAL driver code and with code writing to the register directly.
Best Regards,
Eggers
    Timo Eggers
    Timo EggersBest answer
    Jul 5, 2018 7:47 AM UTC
    Posted on July 05, 2018 at 09:47
    I found the problem!
    You need to start the clock for the Debug Module!
    You need to call __DBGMCU_CLK_ENABLE(); before calling __HAL_DBGMCU_FREEZE_IWDG();
    Timo Eggers
    Timo EggersAuthorBest answer
