Jan 27, 2025 7:01 AM UTC
FR_NO_FILESYSTEM, (13) There is no valid FAT volume
res = disk_initialize(0);
printf("disk_initialize returned: %d\n", res);
if (res != RES_OK) {
printf("Disk initialization failed!\n");
v = 8;
} else {
fres = f_mount(&fs, "", 1);
printf("mount returned: %d\n", fres);
if (fres == FR_OK) {
printf("Filesystem mounted successfully!\n");
v = 5;
} else {
printf("Filesystem mount failed!\n");
v = 9;
got intiailization correct and i tryed f_mks and format the flash ic .
but still occur filemount issue. got no idea where the issue come from . no bug or error .
i see this on debug window
Thread #1 [main] 1 [core: 0] (Suspended : Signal : SIGINT:Interrupt)
main() at main.c:135 0x80003a4
i am using nucleo f302r8 board and w25q64 winbond flash ic
anyone have any idea?
AScha.3
AScha.3Best answer
Jan 27, 2025 8:40 AM UTC
Yes. Read here in forum -> search ... sd
& also my posts, how to begin and avoid basic errors/problems .
AScha.3
AScha.3Best answer
Jan 27, 2025 8:46 AM UTC
i dont get it .
AScha.3
Jan 27, 2025 8:54 AM UTC
see: your not the first, to have this problem.
So look, what are the steps, to get it working: correct hardware setup, etc.
https://community.st.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&q=sd
-> 4,000 results !  a lot to read...
Its "normal" - in my sd-card tests it never worked instantly , just by connecting some wires and any sd-adapter.
So "standard" is not working, at start...
