papageno
Mar 15, 2021 7:56 PM UTC
float correctly displayed in debug but not in release.
Dear experts,
i try to use the float library with printf or vsnprintf. The option nano has been checked, the -u _printf_float too. The latest version of STM32cubeIDE, the proc is STM32F446RE. The value of floats are correctly displayed in debug but in release, it displays a wrong value. The value are mean and median computed values. I suppose there is a problem with a library in release. I really thank you for your help.
Regards,
pap
papageno
papagenoBest answer
Mar 16, 2021 1:10 PM UTC
Erratum: My apologies, the float lib in nano is ok. After searching a little, i found that the problem I had was incorrect data from upstream capture using IT and ISR: the data processed was corrupted in release configuration but all was ok in debug. The reason: I was calling the HAL_TIM_ReadCapturedValue(htim, TIM_CHANNEL_1 ) function from ISR. Replacing this call by htim->Instance->CCR1 inside the ISR solved my problem and data in the array is now correct and the mean and median functions can process correct data and give correct float results. I let the solution of my problem which was not a real problem on the forum, maybe it can help somebody else.
Sorry for the inconvenience.
papageno
papagenoAuthorBest answer
Mar 17, 2021 7:41 PM UTC
Hi @papageno​ ,
Glad to know that your issue is solved :smiling_face_with_smiling_eyes: and thanks for sharing the solution, it should be helpful for the Community.
Imen
